Hey. Im from india!
Specs : -
i5-3470
8gb ddr3 ram
1 tb hdd
660 ti
b75-d3h motherboard
Im running 2 monitors :
1 x 24 inch dell led on my 660ti
1 x 17 inch dell lcd on my onboard card
These are my temperatures when idle
When i start browsing and watching a tv show which btw is 480p, not full screen, the CPU temp rises to 53-55 ish.
And when im playing CS GO on the lowest settings on 1080p resolution for 10 minutes :-
THIS spikes to 83 too and then the pc starts beeping for warning me...
And this is when i play Shadow of Mordor at medium settings with vsync off for just 1 min :
And as soon as i close the game down, the temps are fine.
This has been happening only in the recent few days after i starting messing with the case fans that i bought.
I recently re did my thermal paste on my cpu with arctic silver ceramique 2 paste.
My CASE : cooler master k380
fans :
1x default fan that came with case ( 120mm coolermaster)
1x Cheap 80mm fan that i had from old pc
1x deepcool xfan120
1x cooler master xtraflo 120mm
- Fan on the side panel is blowing air into case (xtraflo)
- Fan on top of case (80mm) is blowing air into case
- Fan on the front (120mm ) is blowing air into case
- Fan at the back of the case (deepcool 120mm) is blowing air out of the case.
Here are few pics of my case and the cable management :-
1.
2.
The cable management got a bit screwed after i installed the fans cuz the fans have small cables so i needed do it like this :/
Can someone help me out? Whats wrong here? My are the temperatures shooting up so bad?
Is it cuz how i placed the fans, or my cpu is bad?
I should point out that both games used to run fine before.
Specs : -
i5-3470
8gb ddr3 ram
1 tb hdd
660 ti
b75-d3h motherboard
fans :
1x deepcool xfan120
1.
2.
