Recently got a new motherboard and CPU (Ryzen 7 3800x and Asus ROG Strix x570-f), I built the pc all fine (had a bit of trouble with the CPU cooler but I tried again and made sure the thermal paste was applied correctly). However, the temperatures on idle are fluctuating around 40 - 50 - 60, mainly it stays on 50 but every few seconds or so it jumps to 68 and then slowly goes back to 50 then it repeats. I have a friend who has the same CPU who says this happens with his also, I'm just looking for more clarification that this is normal because 60 degrees idle doesn't seem to good to me.
Also, my frames are weirdly capped 144, in 'Mordhau' I have V-sync off, I have the setting in game off, I have Riva Tuner off. I can't think of any other reason it should be capped, yet it is.
And another major point which has been really annoying me from the start of getting my PC, my performance is utter trash no matter what I do. I have a better pc than my friend yet he gets around about 30 FPS more than me in Destiny 2 (this was with my old PC), even with my new PC after one test I'm pretty sure I still get less frames than him!! I have a RTX 2070 Super and he has 2060 super, how is that possible (I also have a better CPU). In Mordhau with my new setup I get 144 frames on low 130-40 on medium and only around 100-120 on ultra, this surely isn't normal for my pc, the usages while on medium sits at around 30% on CPU and 50% on GPU, while in ultra it's 30%CPU and 70% GPU, while in low they are both around 20-30. Why is there not more usage, I just don't get it.
