My idle temp is between 40-60C and when i let HWMonitor run and leave the computer running it shows that max temp even goes to 80C
Im using stock Cooler on my i5 3570k
I reapplied thermal paste thinking that it must have dried up stock paste because it is now 2.5yrs old but temps are still high, and im not overclocking at all
Thermal paste used is Cooler Master IC V1
Prime95 on full load taked my CPU temp to 90C+ in 5min or even 3min
I know that these temps are not normal so what is the problem
CPU hungry games like DOTA 2 rockets up my CPU temp to 90C in 10min
And about airflow, it is not very ideal
I have only back 120mm exhaust ON and front 200mm(with my case) is off because there is no option to turn off red LED with it and no one on this forum has helped me in fixing that problem(which wire should be cut in order to cut off LED)
But temp wasn't a problem for more than 2 years with same config and nowadays room temp is also very less due to winters(10-15C)
I have Cooler Master enforcer case
Specs:
i5 3570k
600W corsair
8GB Ram
HD 7950 3GB boost
Specs:
i5 3570k
600W corsair
8GB Ram
HD 7950 3GB boost
