Cpu Temps High
Mr_Cactus
64
I recently upgraded my watercooled pc with a better radiator and six scythe gentle typhoons. They run at about 1500 rpm, and my cpu idles at 30 C, its great! but under load, my temps have jumped up 15 degrees. it now runs at 80C under load, and Im worried my small rice grain size of thermal grizzly kryonaut wasnt enough. Will it spread out and get better temps? Or should I disassemble my loop?
2x EK PE 360mm Rads, 6x Nervo Gentle Typhoons @ ~1320 RPM, (60%) of the full 2200 rpm, which the degrees only rise by about 5 C when running at that speed. here is a pic of my loop.
http://imgur.com/EELJM4D
http://imgur.com/a/IyLDS
I concluded that my temps are higher than before due to the pump running slow for some reason. I will be reseating the pump and retrying this loop in a month when I purchase my second gtx 1080.
https://gfycat.com/SilentBraveLacewing
