CPU temps idle at 60 - 70 degrees Celsius (Even after buying a new CPU cooler!)
HarryChandler
Commendable
Sep 20, 2016
8
I am getting CPU temps of anywhere between 60 and 70 degrees Celsius idle. I have nothing running and the temps are so high. I was using the stock cooler for my CPU and thought that may be the problem so I have just bought a new CPU cooler (Noctua NH-U9S) and applied fresh thermal compound to the CPU. Still the same temps. I have no clue to what the problem is now, and I need help 🙁
Thanks, (PC Specs below)
OS - Windows 10
CPU - AMD A10-7700K Radeon R7, 10 Compute Cores 4C + 6G 3.40 GHz
GPU - GTX 970 4G
RAM - 8.00 GB
it´s easier than you think.
download the up to date BIOS file from the motherboard´s homepage and extract it onto an USB flash drive and reboot. Enter BIOS search there for ez-flash and click on it. Choose the bios file on your drive and flash.
windows is not as reliable as BIOS flashing and could be problematic if it crashes or freezes while updating
Yeah, that sounds like either:
a) Bad sensor, or
b) software not correctly reporting
Idle temp should be closer to 40degC but it varies a lot depending on ambient temp, case cooling, cooler and fan profile setup.
Other:
- ensure fan is spinning
- install motherboard fan control software if possible (may be in bigger software package)
I am using CAM to measure temps. I just tried downloading AMD OverDrive and got it installed and everything, but when i open it, it comes up with a warning saying stuff like its dangerous to overclock blah blah blah. Then i click ok, and my PC just turns off. tried it twice now and it just turns it straight off.
What motherboard & bios revision??
Cam (if if its the latest one) should have the amd algorithms embedded so it 'should' read temps fairly accurately.
Amd overdrive should not crash out like that though seeing as its designed expressly for amd boards & CPU's.
Try running as administrator??
How do I check my motherboard & bios revision? I uninstalled and reinstalled AMD OverDrive and it still turns my PC off when I click ok. No warning or anything. straight off and resets itself back on. (tried running as administrator and it crashed too)
little side note, My PC does crash and give me the BSOD. But it doesn't do it when i am playing or using my pc. it only happens when I have left my PC on with nothing running. After anywhere between 30 mins - 1 hour it crashes. the crash says UNEXPECTED_STORE_EXCEPTION and sometimes says CRITICAL_PROCESS_DIED. It has done this ever since I can remember putting my PC together (which is like 1 year). I have reinstalled Windows and everything, and still the same problem. I am just letting you know this as it might be connected in some way to the CPU temps.
Most likely your temperatures are fine. You'll get nonsense readings from anything but Overdrive. People ask this question multiple times every day, some claiming programs were reading that their CPU was at 130c or above, which is impossible as the CPU would immediately shut itself down from thermal protections being tripped.
As others have noted, only AMD Overdrive is accurate for AMD processors.
CAM is somewhat unreliable (I've used it myself) depending on which version you use. At one point it looked like they adjusted for the erratic readings so 60 deg C at idle read 20 deg C idle, but then promptly changed it back to the 60 deg C idle reading. If a sensor accurately measures the change in temperature, then I would have presumed it was possible to adjust the software to report the correct temperature. (This doesn't seem to be the case though.)
However, through much comparison on my own system; 60 deg C idle on CAM isn't too bad. At around 95 deg C, CAM claims overheating while AMD Overdrive has thermal margin of 30 deg C. Assuming such readings are consistent across different processors, I don't think there's anything to worry about.
The problem is that AMD overdrive is crashing the system when running it. Something is wrong, but not sure if it´s software or hardware related.
Update the up to date BIOS for your motherboard. The exact motherboard model name can be read with cpu-z. Don´t flash in windows! use the integrated tool integrated in BIOS
Model - A88X-GAMER
Rev X.0x
Can you explain how I do that a bit easier? What do you mean don't flash in Windows?
Thanks, your solution fixed my blue screen crash problem which I had been having for a while now, but didn't fix the CPU temp problem on CAM. It isn't really a big problem for me right now as it isn't really affecting me or my PC (as far as I am aware) so I will leave it for now. I may get a new CPU in the future and hopefully that may fix it, but idk. Thanks anyway for fixing my blue screen problem :)
Hey,
I've seen others report the temperature sensors are bad for some AMD processors.
For example: http://www.eteknix.com/complete-amd-kaveri-review-a10-7850k-a10-7700k-a8-7600/16/
"In terms of temperatures with Kaveri it isn’t possible to judge. The temperature readouts on the Kaveri APUs are totally “borked” and the motherboard sensor readouts give ridiculously low temperatures which cannot be accurate... "
*As long as you don't see a BSOD or other signs of data corruption then I wouldn't worry about it. I don't think you should overclock though since it's obviously hard to see what the actual temperatures are. I suppose you could still do a light overclock and leave it there if no crashing. Up to you.
Other:
I also suggest running Memtest86 if you haven't done so (for a full pass), or at the very least use the Windows tool (type in "memory" into search to bring up the Windows Memory Diagnostic. Either way, a full pass takes roughly 30 minutes per 8GB of memory depending on the speed of memory).
Other:
Your next CPU upgrade will require a new motherboard and memory. There's not much you can buy that is worthwhile as an upgrade for your current system.
So you should be looking at either a suitable Intel setup such as the i5-6600K, i7-6700K or later (depending on budget and time of purchase) or possibly a ZEN processor.
I think Zen is coming to 28nm on AM4 motherboards but I'd wait for the 14nm processor (on the same motherboard). That's on an AM4 motherboard using DDR4 system memory (i.e. 2x8GB 2666MHz).
I'm hoping Zen is very competitive for pricing, however unless there is significant SAVINGS to be had on the CPU I'd stick with Intel as their software is more mature in general, though you should INVESTIGATE that later. Remember it's also the CHIPSET and driver support for SATA, USB, network etc.
*I also recommend waiting at least TWO MONTHS after any specific motherboard is made to allow for BIOS updates to sort out various issues. It's very common to see changes, especially on such a new platform.
(For video editing, what I really want is an inexpensive dual-socket motherboard and reasonably priced 8C/16T processor. Currently the cheapest Intel is about $1000USD. Ouch!!
What's really interesting is that a 4-core Intel now can use about HALF the space for the graphics. So it's possible to make an 8-core without graphics for about the same price. So how come an 8-core is $1000? Competition. AMD will not have graphics on the CPU since that's what an APU is. So how much will their 6C/12T and 8C/16T processors cost? Who knows.
I suspect the 8C/12T Zen, 14nm CPU's will cost between $600 and $800USD and the 6C/12T CPU's will cost $300 to $500USD)
