Question CPU Temps in NZXT H510i
May 6, 2021
Hi,
Like a month ago i finished building my first gaming PC:
i7 12700k on Gigabyte Z690 AERO G
32GB of 4800MHz Kingston Fury RAM
Gigabyte Vision RTX 3080 10G LHR
Lian Li Galahad 240 CPU Cooler
Corsair RM850 2021 Edition PSU
Built in the NZXT H510i Case
I've got the 2 included case fans in the back and top getting air out of the case and the AIO in the front pushing air in the case through the radiator
Idle temps are 24-30C for CPU and 47-50C for the GPU
Yestarday I decided to stress test my PC
I ran Cinebench R23 and FurMark at the same time for 30 minutes
These are my recorded temps of the last 2 minutes of testing:
16.3.202207:03.610075.792.11879.9100881004333.347003600
16.3.202207:05.710075.491.71896.110088974333.347003600
16.3.202207:07.810075.792.21890.978.468834333.347003600
16.3.202207:09.910075.591.91872.798.188974333.347003600
16.3.202207:12.010075.692.21888.710088974333.347003600
16.3.202207:14.110075.592.21891.310087974333.347003600
16.3.202207:16.210075.592.11869.910088974333.347003600
16.3.202207:18.310075.692.11894.110087974333.347003600
16.3.202207:20.41007692.71886.2100881004333.347003600
16.3.202207:22.510075.592.21875.810087964333.347003600
16.3.202207:24.610075.691.91896.510087974333.347003600
16.3.202207:26.710075.692.11876.710089974333.347003600
16.3.202207:28.810075.892.51870.810087984333.347003600
16.3.202207:30.910075.692.21889.910088974334.44701.13600.9
16.3.202207:33.01007692.71891.810088984333.347003600
16.3.202207:35.210075.792.21871.410088984333.347003600
16.3.202207:37.310075.792.3189310088974333.347003600
16.3.202207:39.410075.592.11886.510087974333.347003600
16.3.202207:41.410075.992.51873.910088984333.347003600
16.3.202207:43.510075.491.81898.310088984333.347003600
16.3.202207:45.610075.592.11876.175.980904333.347003600
16.3.202207:47.710075.792.21883.110087964333.347003600
16.3.202207:49.810075.391.71887.610087964333.347003600
16.3.202207:51.91007692.51892.610087974333.347003600
16.3.202207:54.010075.692.21868.210089984333.347003600
16.3.202207:56.18675.992.61892.910087964333.347003600
16.3.202207:58.210075.992.61887.910089984333.347003600
16.3.202208:00.310075.491.81870.510087964333.347003600
16.3.202208:02.510075.692.21893.310087974333.347003600
16.3.202208:04.510075.992.4187910088974333.347003600
16.3.202208:06.610075.892.11880.610087974333.347003600
16.3.202208:08.710075.6921884.210088974333.347003600
16.3.202208:10.810075.6921892.210087974333.347003600
16.3.202208:12.910075.7921870.210088974333.347003600
16.3.202208:15.010075.491.81891.710088974333.347003600
16.3.202208:17.110075.6921891.110088974334.44701.13600.9
16.3.202208:19.210075.792.31868.510088974333.347003600
16.3.202208:21.210075.992.51891.410088974333.347003600
16.3.202208:23.410075.992.51880.77564744333.347003600
16.3.202208:25.510075.892.31876.699.487974333.347003600
16.3.202208:27.810075.892.51882.310088974333.347003600
16.3.202208:29.910075.892.21891.910088974333.347003600
16.3.202208:32.010075.692.21869.810088974333.347003600
16.3.202208:34.110075.491.71889.510087974333.347003600
16.3.202208:36.210076.393.11886.410087984333.347003600
16.3.202208:38.310075.892.71872.610088984333.347003600
16.3.202208:40.410075.692.11894.710087974333.347003600
16.3.202208:42.510075.792.11886.510089984333.347003600
16.3.202208:44.610076.292.8187210088974334.44701.13600.9
16.3.202208:46.710075.892.41877.210087974333.347003600
16.3.202208:48.810075.892.31893.410088974333.347003600
16.3.202208:50.910075.992.61876.510088974333.347003600
16.3.202208:53.010075.892.21884.8100891004333.347003600
16.3.202208:55.110075.792.21892.510088974333.347003600
16.3.202208:57.210075.5921866100891004333.347003600
16.3.202208:59.310075.391.71889.610089984333.347003600
16.3.202209:01.410075.892.2188632.75162445047003800
16.3.202209:03.41007692.51880.39.95062440047003800
DateTimeGPU Core Load [%]GPU Temperature [°C]GPU Hot Spot Temperature [°C]GPU Effective Clock [MHz]CPU Usage [%]Core Temperatures (avg) [°C]Core Max [°C]Core Clocks (avg) [MHz]P-core 0 Clock [MHz]E-core 8 Clock [MHz]
GPU [#1]: NVIDIA GeForce RTX 3080:GPU [#1]: NVIDIA GeForce RTX 3080:GPU [#1]: NVIDIA GeForce RTX 3080:GPU [#1]: NVIDIA GeForce RTX 3080:CPU [#0]: Intel Core i7-12700KCPU [#0]: Intel Core i7-12700K: DTSCPU [#0]: Intel Core i7-12700K: DTSCPU [#0]: Intel Core i7-12700KCPU [#0]: Intel Core i7-12700KCPU [#0]: Intel Core i7-12700K
I am quite concerned about my CPU temps in this Case. As you can see the hottest cores managed to hit 100C in 30 mins of stress testing while running at a 22-23C ambient temperature. My room gets quite hot on summer time, in the 27-28C range, so I'm worried I might have some issues.
Having the exhaust fans set to Performance in NZXT CAM, which gets them up to 100% at 65C CPU temp, the pump at 100% all the time, the AIO Fans on silent mode which gets them to 100% at like 70C CPU temp, and the GPU Fans on Auto, so they were averaging around 87-88%.
What should I do to improve my temps? I thought about a push and pull configuration on my radiator, but I'm not quite sure on that because I only got about 3cm of space between my GPU and radiator. I'm afraid of having to either swap out the Case for one with better airflow, or having to mod it to add a mesh in the front.
Hope someone can help me out, Thanks!
1)You get a more airflow friendly chassis. 'Meshing' the front panel out may not be a drastic improvement - at least in GAMING loads, and on AIR cooling - as shown here, with the stock fans Vs what are supposed to be better fans:
View: https://www.youtube.com/watch?v=10ERchM9Q6g
(check out 3:35 to 4:27)
2)NEVER stress test the cpu on auto Vcore. At least find a stable manual or offset voltage before doing so - stress testing will almost always come out subpar or poorly if you don't.
3)Adding to point 1, Regular H510 isn't particularly AIO-friendly. That front panel is too restrictive; you're largely choking the cooler. Air coolers are more effective in there as they sit towards the center, and because of that, are harder to choke.
