I recently performed some basic cleaning on my home PC. Here are the specs:
AMD FX 8350
MSI 970 Gaming Mobo
LEPA AquaChanger 240 Liquid Radiator
I took apart the system for routine dust cleaning, and in doing so I noticed that one of the 120mm fans on the radiator wasn't any good (the other was fine, so I replaced it with a Best Buy one.) I took the block off of the CPU, cleaned both the CPU and block with polish remover, and added a rice-size bead of thermal paste to the system and re-installed it. After re-installing all components I booted up the system, and let my kid play on it for awhile. After a few minutes he told me the system shut down.
Checking the MSI on-board specs, I noticed that the CPU temp would spike to 91C and then shut down. I checked with LEPA, and unfortunately it's out of warranty. As far as I can tell, I think the CPU water block is powering up just fine, the lights come on on the LEPA, and I think i feel the motor going, but I'm not sure what diagnostics I can perform to make sure. All the other fans run just fine.
AMD FX 8350
MSI 970 Gaming Mobo
