Image above : Running Prime95 on small ftt for heat benchmark
Greetings everyone,
I am having very high idle CPU temps around 45-50°C weather in my room is around 20°C
when i play games my cpu temps go up to 70-80°C and the games are unplayable
very bad performance and a lot of FPS Drops
My CPU is Q9950 and Intel says its TCase max is 71.4°C also i did some research to other peoples temps and results are that the TJunction max temps are arround 71-75°C
I am not an expert with temps and all so i though you guys could take a look because i cant understand if my cpu is throttling why my clocks are not downclocked ? i was running Prime95 results as well with temps monitoring and no downclocks
CPU - STOCK FAN
Intel® Core™2 Quad Processor Q9550
(12M Cache, 2.83 GHz, 1333 MHz FSB)
