I'm thinking about upgrading my CPU, and I'm enough of a noob to not be exactly sure which is the fastest (or best). Or even if it's worth it, for that matter.
Here's the processor upgrade info from the HP website:
Socket type: AM3
TDP:
Motherboard supports the following processor upgrades:
•AMD Athlon X2 (Bt)
•AMD Athlon 64 X2 up to 6000+ (W)
•AMD Phenom Triple-Core up to 8xxx (AM2+) (Toliman)
•AMD Phenom Quad-Core 9xxx series (AM2+) up to 9850 (Agena)
I currently have the stock Athlon II X64 620 installed. Is picking the fastest CPU as simple as going with the last one on the list -- Phenom Quad 9850? That would run me about $60 right now.
If it helps any, I'm wanting to run Adobe CS5 (mostly Premier Pro) to make films. I already upgraded the PSU to 800w, the RAM to 8GB DDR2, the video card to the GTX 470, and Windows 7 to Pro (64). Also thinking about upgrading the RAM to 16GB.
My other option is to buy an i7 setup with 12 or 24 GB DDR3, and move the upgraded PSU and GTX 470 over into the new rig. Thoughts or advice? Thanks.
Socket type: AM3
TDP:
•AMD Athlon X2 (Bt)
