Question CPU Upgrade Options For Ryzen 3 4350g?
Apr 8, 2024
9
Hey Guys, I Need Help in upgrading my CPU I am a content creator. I Play games and record them I Want to do streaming also These are my current pc specs
CPU: AMD Ryzen 3 PRO 4350G with Radeon Graphics, 3801 Mhz, 4 Core(s), 8 Logical Processor(s)
Motherboard: A320M-A PRO (MS-7C51)
Memory: Corsair 16GB (1 x 16GB) DDR4-3200
GPU: ASUS GeForce GTX 1060 6GB ROG Strix
PSU: ZEBRONICS (ZEB-VS600Z)
I can only go for am4 right now I don't have budget for am5 because I have to buy then am5 socket motherboard as well so suggest me a good am4 CPU which can help me in streaming as well on 1080p.
Buying From Amazon IN
R5 5600(x) or even 5700(x) is most I would dare put on that MB and retain their full compatibility and performance and have a substantial boost.
RAM you definitely need more. 2x8GB at minimum or 2x16GB even better, at 3200MHz. RAM is now at lowest price point in long time.
Streaming needs a lot of cores and RAM.
PSU should be adequate for now unless you upgrade GPU too.
Reactions: Mohit creed
In R5 5600(x) or 5700(x) which one would you prefer? Is it good to pay 40% extra for 2 cores I mean is it worth because I have a very tight budget and I just want to do a stream. 😀
And Thank You for suggesting me upgrade part will do it in future.
You could get by with 5600x , certainly much better than what you have now. But it's not only 2 cores more but also 4 threads which in most cases count more than cores. A thread uses part of CPU for computing while other part of CPU core is receiving information and therefore busy, With 5700 you would more than double processing power over 4350. you can also look up 5700 non x which should be cheaper than x model but still better than 5600x,
Thank you so much for the help
I have one another concern related to CPU cooler which one is good
1: - Cooler Master Hyper 212 Spectrum V3 ARGB CPU Cooler - 120mm Fan | Support AMD & Intel CPU Socket AM5, AM4 / LGA 1700, 1200, 1151, 1150| PWM Case Fans | 71.93 CFM Airflow | 4 Heat Pipes
2:- Deepcool AG400 ARGB Single-Tower 120mm CPU Air Cooler/CPU Fan | Support : Intel LGA1700/1200/1151/1150/1155 and AMD AM5/AM4 - R-AG400-BKANMC-G-1
Or if you have any recommendations please tell me...
5700x and 5700g are on the same price ($224) and 5700 is not available should I go with 5700x?
The price of 5600g is ($159)
Yes, 5700x. You already have a decent GPU, so the 5700G integrated GPU wouldn't be that useful. Unless you wanted to run displays off the motherboard in addition to the 1060.
Is it going to bottleneck my GPU? As I need a CPU for streaming purposes
Not really how that works. If anything the older GPU is the bottleneck, but I don't like that term. Your total system performance won't go down with faster parts, only the capability to go up. Now for gaming a big CPU increase means more potential FPS, but only if the GPU can produce the appropriate frames at the settings you run.
If you use the CPU for streaming you want as much processing power as you can get.
5700X is just slightly faster and has double the cache, but it doesn't have onboard graphics like your 4350G, so if you make use of that then it would go away.
https://www.cpubenchmark.net/compare/4323vs4814/AMD-Ryzen-7-5700G-vs-AMD-Ryzen-7-5700X
