Hi. I tried asking a couple of things on an older thread from this morning but i have more questions.
I've upgraded my CPU from E2160 to E7600. My Motherboard supports it and it works fine. Well, not fine. Once it is installed, the fans in the whole system ( connected to the motherboard, which is the CPU + rear fan) speed up to their maximum and not stop. Also, the sound and the system itself is sped up by a couple of times. Some sounds are normal but others, such as Opera youtube or something, work sped up but the video is fine. Also, even the Windows loading is sped up and circles alot faster then usual. Temperatures are cool, 33c on the CPU so i don't think the temperatures are bad. Motherboard supports the CPU, although it is the strongest CPU i can get for the motherboard (MSI MS 7525 vers 1.0). And, the CPU doesn't want to boot up after a second restart. It loads up the first time right after hot swapping with the old E2160, but after restarting, it just freezes on Windows logo loading. Sometimes even popping a "Activating Repair system" with no response. No loading circle at all. What should i do?
DirectX is updated and new. (one user suggested installing that for the sound, but no fixes)
Temperatures are fine.
CPU pins are not bent and the CPU is supported by the motherboard.
Hotswapping to an E2160(old CPU) starts the system just fine, i'm using it right now.
CPU is recognized by the BIOS and the CPU-Z as a true and flawless E7600.
Fan speeds are not configurable by the end user(atleast not on my BIOS version) which i'm scared to flash since i found the perfect BIOS file for the motherboard and the newest one, but i don't know which flasher to use for my system. I'm scared that the fans might be on over-voltage and fry themselves. Should i install a new System in order for the CPU to optimize itself for the system? How should i do it? Should i use the E2160 for installation or should i use the E7600 and just go ahead?
Help out!
Help out!
