PC Specs:
CPU: Ryzen 5 3500X (OCed to 4.2Ghz@1.375V in Override mode)
Motherboard: MSI B450M Pro VDH MAX
RAM: Corsair Vengeance LPX 16GB (2*8GB) 3200MHz
GPU: Gigabyte RTX 2060 6GB OC
PSU: Corsair CV650 650W 80+ Bronze
CPU Cooler: Thermaltake UX200
*OS Installed on a 120GB SATA SSD
*Other Files on HDD
*Gaming on Samsung PM91A 512GB NVMe SSD
Whenever I turn on XMP profile CPU usage become insane (80-100%) and start to lag everything. Games FPS goes to 30 from 70. Discord uses 80% of CPU while launching. It was not like that before. I have been using this CPU OCed for more than 2 years (Did I kill my CPU
) and everything was running perfectly. CPU was performing better than default setting and even temps were better (Never crossed 70).
But recently installed Windows 11 and after 2 days CPU starts to show these symptoms. Flashed latest BIOS and went back to old ones but the result was same. Went back to windows 10 but...
The only solution I found myself was turning off the XMP and everything running well. But there's some (sometimes more) performance penalty when RAMs are running at 2133Mhz instead of 3200MHz.
WHAT SHOULD I DO?
*Other Files on HDD
WHAT SHOULD I DO?
