[SOLVED] CPU Usage Issue
adriand431
5
My CPU usage is at 60-99% because of this thing called
""Services and Controller app""
Im unable to run CSGO with this and I can't force it to close via Task Manager.
Due to the Windows 10 update, this problem seem to be common
try go to Command Prompt > Run as adminstator, then try these command
"DISM.exe /Online /Cleanup-image /Resorehealth" then press Enter
"sfc /scannow" then press Enter
Hope this help!
Hope this help!
First command failed and ended up with "Error :87"
Second command is currently executing.
