Question CPU voltage keeps changing
jaaprikm
34
Heyo!
I don't know if this is common, but my cpu voltage is normally at 1.4 But every like 5 seconds it changes to \ 1.39 or 1.41 causing my cpu to heat up like 7 degrees for a seconden and cooling down again. This is a constant loop.
Anybody who can maybe help me?
My CPU: AMD ryzen 2600x
Data: Ryzen Master
I did not oc my cpu in any way btw
Thanks in advance!
Do your fans spike along with the CPU? If they do it may be a software problem. Check task manager (Performance > CPU) then click CPU to prioritize programs highest to lowest to see what causes the throttle.
