A humorous title for fun. Anyway, thought maybe someone could help me with my issue with my cpu fan.
Here's what happened:
One day I thought it wise to remount the CPU cooler. I was running a few degrees above normal, so I gently removed thermal paste and remounted the heatsink onto the CPU with thermal paste. The computer boots up and all is well.I run 31-33 c, still hotter than my normal temp, but oh well, I think.
Later I open up the computer for wire management. I dust with canned air and boot up to bios to monitor the temp. All is well, but always notice rpms on my CPU fan are in 600's. I put a setting for CPU fan to turbo, just to see what'll happen. Mistake. Once booting into windows, the CPU fan revs up crazy and gets louder and louder as though going to explode. I quickly shut off.
Fast forward again, I boot to bios ( fan is fine in bios, temp is 35 though) and change motherboard CPU fan speed from 'Turbo' to normal. Restart. Try to boot to windows, same result. Fan is fine in bios screen but when booting to windows there is an issue and that CPU fan simply wants to rev up and explode. Nothing obstructing CPU fan and heatsink is mounted nicely with not too much or too little thermal paste. Motherboard fan speed is still 'normal.'
Should I remount? Any ideas?
Thanks,
Nat
Thanks,
Nat
