G
Guest
Guest
I'm planning on switching to a water cooling system very soon. I just want to water cool my CPU to overclock my AMD FX 8350. So any water cooler is fine with me, but preferably the XSPC Raystorm 750 RS240. My gaming case of choice will be the Enermax Ostrog GT mid tower. I'd like to be able to use the XSPC Raystorm 750 RS240 mounted to the top, but not sure if the radiator will fit. Also, I like the Cooler Master Nepton 240m AIO. I've seen reviews, guides and looked up the specs, saying it can support 240/280mm radiators at the top. However, they say it's a tight fit so there's the possibility to having to off set one or both the fans to make some adjustments. So my question is: will either the XSPC Raystorm 750 RS240 or Cooler Master Nepton 240m do the job for this case? Thanks in advance! ^^
