Hey guys,
I got a small problem with the sound on my system. I'm currently using the onboard audio of the Gigabyte GA-Z87-D3HP.
When I have my headphones on(I use them around 90% of the time) I can hear a constant buzzing sound. I used to have them connected on the front IO ports, but when I moved it to the rear IO the buzzing was reduced to almost not there. ALMOST though. It's a little annoying.
I was wondering, is it normal, is it fixable? If I use a cheapish sound card(CREATIVE SOUND BLASTER 7.1 AUDIGY SE) will I get rid of the buzzing? I know I will not get better sound quality with a card like this, I just want the buzzing to go away.
Oh, my headphones work just fine on my ps3, no buzzing at all, in case you're wondering.
Thanks guys. Can't wait to read your thoughts.
