CrossFire/ Computer Build Help
Roger Narq
109
I'm looking forward to be upgrading a Radeon GPU and get Crossfire. But I can't find a good GPU for the money. I'm looking for a GPU that is around 100-150, has 2 GB GDDR5, and CrossFire ready. Tell me how my build is going also and give me any improvements. This is meant to be kind of a budget build that can be upgradeable later. Thanks! :)
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811139028
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103962
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817182071
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
Disk Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
OS: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
The FX-6300 is much better for gaming than the first gen FX-6100. Also, at graphics cards in this price range it's not worthwhile to go for crossfire, a more powerful single you solution is best. For a gpu at around 150 get the HD 7850 or spend 30 more and get the HD 7870
I would do that, But I have a limited budget. That's why I'm getting ready to upgrade later so I can do so without spending a lot of money for getting new parts for that upgrade.
