Crossfire, Please help!!
George002000
438
Hi there guys I've had my second graphics card in my PC now for 2 weeks and are wondering if I've got my crossfire on. I've gotten two R9 290 Tri-X Sapphire cards with a Z97-K motherboard. These cards use the AMD CrossFireX, This motherboard does support this and I can't seem to get my crossfire working. I go into the CCC (Catalyst) and go on to the "Gaming" and there isn't a CrossfireX, These cards DO NOT NEED THE CROSSFIRE BRIGE. These two GPU's are working because I switched them around and they work and in device manger there both coming up and it says "working properly" I've been able to run a monitor off the second GPU so I know it's working fine. Does anyone know what my problem is and if I need to enable crossfire in my motherboard BIOIS.
Please help
Thanks so much.
First of all, i do not know why you decided to crossfire on that board at all, as the second slot runs at X4.
1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
1 x PCIe 2.0 x16 (max at x4 mode, black) *1
X4 mode cant support Crossfire with that card, the bandwidth is too low. In other cases having a lesser powerful card in X4 works, but your motherboard is the problem here.
I done all of this and it's still not got an enable crossfire button, do you know why?
So I need to get a new motherboard?
What motherboard would you say? That doesn't cost to much money and supports the i7 2790k ➖
CPU
So at the moment the 2nd card isn't running at it's full extent? and if i get one of these motherboard's the 2nd one will be running as fast as it can?
