Question Crosshair viii extreme
Matthew44
52
hi everyone, im thinking of building a £4700 gaming pc next year, im thinking of getting the lian-li pc case or cooler master h500P case. i'd prefer the h500p as it has 2 200mm fans. however, looking at the dimensions, the board is slightly bigger, being at
12.0079 x 10.9055 where as the case dimensions for an eatx pc board is 12" x 10.7") it is stupid that im asking, but would it just about fit? (i already have the 360mm sat on my shelf)(another stupid question, should i buy a new aio however, it was used for less than 30 days but wont be used until after 10/11/23. would that still be ok?)
Full pc specs for next year:
pc parts for late 2023
I have fit many e-ATX motherboards in cases that state a max of ATX, that being said it usually will cover up the cable management holes and be a super tight fit.
Reactions: Matthew44
A year is a long ways away. By then Intel Raptor Lake and AMD Ryzen 4 will have been released along with Nvidia's 40XX series graphics cards. Best to start these threads no earlier than two weeks before you plan on purchasing. With that said with your budget I'd run that build like this if I were making the purchase tomorrow.
https://www.box.co.uk/Lancool-II-me...Lancool-II-Mesh-Performance-Temp_2994935.html
Lian Li Lancool II Mesh Performance Tempered Glass Mid Tower Case £88.99
https://www.awd-it.co.uk/components...-modular-power-supply-unit-cp-9020201-uk.html
Corsair RM1000x (2021) 1000W 80+ Gold Modular Power Supply £136.99
https://www.cclonline.com/mag-z690-...rpedo-atx-motherboard-for-intel-lga1700-cpus/
MSI MAG Z690 TORPEDO £249.97
https://www.technextday.co.uk/produ...cessor-8-cores-5-0-ghz-alder-lake-lga1700-cpu
Intel Core i7-12700KF £363.83
https://www.amazon.co.uk/dp/B07Y87YHRH
Noctua NH-D15 chromax.black Dual-Tower CPU Cooler £85.98
O/S (Windows) SSD
https://www.amazon.co.uk/dp/B07MFBLN7K
Samsung 970 EVO Plus 500GB M.2 PCIe NVMe Internal SSD £59.99
Storage SSD #1
https://www.amazon.co.uk/dp/B07MLJD32L
Samsung 970 EVO Plus 2TB M.2 PCIe NVMe Internal SSD £187.90
Storage SSD #2
Samsung 870 EVO 2TB SATA 2.5" Internal SSD £201.75
https://www.scan.co.uk/products/32g...00-5600-non-ecc-unbuffered-cas-36-xmp-30-125v
Corsair Vengeance DDR5 5600MHz 32GB (2x16GB) CL36 £189.98
https://www.ebuyer.com/1261416-giga...aming-oc-graphics-card-gv-n308tgaming-oc-12gd
Gigabyte GeForce RTX 3080 Ti GAMING OC 12GB Graphics Card £1,099.98
https://www.scan.co.uk/products/windows-11-home-edition-64-bit-english-international-usb
Microsoft Windows 11 Home Edition 64-bit USB - English £110.48
https://www.currys.co.uk/products/a...27-ips-lcd-gaming-monitor-black-10220251.html
ASUS TUF Gaming (VG27AQ1A) 27" 2K HDR - QHD (2560 x 1440), IPS, 170Hz, 1ms, Extreme Low Motion Blur, Speaker, G-SYNC Compatible Gaming Monitor £299.00
Total: £3074.84 inc VAT
Optional 240mm AIO that top mounts on that Lian Li case.
https://www.amazon.co.uk/dp/B08WRJ5MQW
ARCTIC Liquid Freezer II 240 A-RGB AIO £95.97
A better look at those components.
https://www.msi.com/Motherboard/MAG-Z690-TORPEDO
https://noctua.at/en/nh-d15-chromax-black
https://www.guru3d.com/articles-pages/gigabyte-geforce-rtx-3080-ti-gaming-oc-review,1.html
https://www.intel.com/content/www/u...-25m-cache-up-to-5-00-ghz/specifications.html
i7 12700K / 12700KF gaming benchmarks.
