Crucial and memorystock won't recognize my laptop's model
Mar 29, 2018
6
Hi, there! So, I bought my little brother an used Samsung laptop (NP-RC530-S02IT), a few days ago, and noticed it works good on it's 4gb of ram, however, since my brother wants to run the Dolphin Emulator and Cemu and etc., idk if 4gb would be enough.., so naturally we decided to try and upgrade the RAM.
Turns out most websites won't even recognize the laptop's model though.. I ran CPUZ and it said I have 2 slots 2x2gb manufacturer Samsung, DDR3, So-DIMM, PC3-8500F (533 MHz),1.50 Volts. Can u guys tell me where to look for an upgrade, cause I can't seem to find anything appropriate.
I wanna buy 1x4gb and mix it with the 2gb on the other slot,(yeah im aware it would run at the slower speed of the 2gb) or just buy 2x4gb.
The system specs are:
Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz (2.90 GHz with Turbo Boost)
NVIDIA GeForce GT 540M - 2GB
HDD 500GB SATA
CPUZ's exact ram specs are:
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format SO-DIMM
Manufacturer (ID) Samsung (CE00000000000000000000)
Size 2048 MBytes
Max bandwidth PC3-8500F (533 MHz)
Part number M471B5773CHS-CF8
Serial number 8766BFC1
Manufacturing date Week 10/Year 11
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-15-20 @ 380 MHz
JEDEC #2 6.0-6-6-18-24 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #4 8.0-7-7-20-27 @ 533 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Size 2048 MBytes
Serial number 8766BFB0
Number of banks 8
EPP no
XMP no
AMP no
Thank you in advance.
Latest posts
