I am buying an AMD Ryzen 7 2700x processor. I might do a little bit overclocking as well. I am planning to get a Cryorig R1 Universal Air Cooler for the cooling solution.
Will it be able to keep the 2700x cool with moderate overclocking?
Usually with atx boards there aren't as many issues. I usually recommend gskill ram, but if you have Major fitting concerns consider Corsair lpx ram as it'll fit under most heat sinks
Awesome!
I'm actually planning to get a couple of CORSAIR Vengence LPX 16GB DDR4 3200MHZ RAM
