Okay, so in task manager>Process tab I found 4 csrss.exe process and each take 20%+ cpu. So my cpu is bottlenecking.
I found out in some websites that to get rid of the virus is to end process the csrss via task manager. If no prompt than it really is a virus. And yes no prompt on mine.
Then I go to regedit, but every time The registry editor opened my pc restart itself (not turned off suddenly. But like restarting from the power menu).
So I go to safe mode and i can open regedit without problem. But I'm not found the csrss file so I close it and found out that I'm looking in the wrong directory.
But when I want to run the regedit again there's a prompt saying "registry edit is disabled by admin". I have disabled the prevent access to regedit from gpedit no luck, and I tried from cmd using this command
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System" /t Reg_dword /v DisableRegistryTools /f /d 0
But my cmd show this again "registry edit is disabled by admin"
For now my only choice is clean instal windows. And I'm doing it now.
The question is what should I do if my pc exposed to this virus again? And what antivirus that can blocked this virus.
Thanks
Thanks
