Custom Built Computer Randomly Freezing/Crashing
Apr 3, 2018
4
I have been having this problem for 3 months. After a certain amount of time mostly in desktop I encounter a freeze which forces me to reset the system. After I reset the problem will happen a little faster than before, until it freezes after signing in.
Problem areas are desktop, online mostly youtube, and some games will also freeze. I will also look for any more information. I also did reinstall windows 10 to no effect.
Some times of freezes I noted was stopping a video, and once as shutting down.
Any help would be appreciated. THANKS
System specs
Motherboard: Asrock AB350M PRO 4
CPU: AMD RYZEN 5 1600
CPU COOLER: STOCK SPIRE COOLER
RAM: CORSAIR VENGEANCE LPX 2 4GB STICKS, 2666MHZ. CMK8GX4M2A2666C16
PSU:CORSAIR CX550M
GPU: ASUS DUEL GTX 1060 OC
2 CASE FANS
1 SSD FOR BOOT, 1 HDD FOR Storage
2 MONITERS
The CPU temp is at most 60 degrees Celsius, and low is 33. Motherboard is around 35 degrees. GPU is 40 degrees low, high under stress 75 degrees. Both SSD and HDD are around 36 degrees.
