Hi guys,
Just finished building my PC. Tried to boot it but so far I can't get it to boot properly.
Strangest thing is that I plugged in a PC system speaker, but it doesn't bleep at all.
When I press the power button the case fans and the cpu fan start spinning, the motherboard's RGB lighting does work etc. But whenever I try to connect a screen, it doesn't get a signal. I tried changing the ram slot and I am now even trying it without any ram installed. The manual of the motherboard tells me that I should hear a continuous bleep from the system speaker if no memory is installed, but I hear nothing (I know the speaker works because it works on a firend's PC).
Also something else I noticed, not sure if this is a problem, but I cannot seem to turn off the PC after it has been turned on. Pressing and holding the power button doesn't do anything, I have to flip the switch on the power supply to turn it off.
Anyone has any idea what might be going on here?
Here is the list of components I am using:
CPU: AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor ($318.89 @ OutletPC)
CPU Cooler: be quiet! - PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler ($36.35 @ OutletPC)
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard ($163.90 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Amazon)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive ($94.99 @ B&H)
Storage: Samsung - SM951 256GB M.2-2280 Solid State Drive
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB AORUS Video Card ($669.99 @ Newegg)
Case: Fractal Design - Define S ATX Mid Tower Case ($89.98 @ Newegg)
Power Supply: Corsair - RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($98.90 @ OutletPC)
Total: $1627.99
Generated by PCPartPicker 2018-09-27 16:27 EDT-0400
Total: $1627.99
