Custom Built PC not sure if it will work.
predalien19
Hello,
I'm building a custom computer and I'm not sure if everything's going to be compatible so would you be able to let me know if it is? Also could you tell me whether the motherboard has a built in sound and network card? Thanks
ah, sorry about that it didn't copy in. here it is:
Intel Core i5 3570 LGA1155 CPU 3.4Ghz 6Mb Cache Ivy Bridge
Intel BXRTS2011LC High Performance Liquid Cooler
Gigabyte GA-H77M-D3H MB, Intel H77 Chipset, Socket 1155, 4x DDR3, SATA3, USB3.0, GbLAN, 7.1 CH,
Corsair 8GB (2x XMS3 4GB) CMP8GX3M2A1600C9 PC3-12800 (1600MHz) DDR3 RAM, 2x240 DIMM, Unbuffered, 9-9
Western Digital 1TB SATA3 64M(WD1002FAEX)
Corsair 180GB Force Series 3 SSD
Gigabyte ATI HD 7750 OC 850Mhz 2GB DDR3 128bit PCIE2.1 HDMI DVI D-SUB
Samsung S23B300BS 23inch LED D-Sub DVI 5msTilt Gloss Black
Samsung SH-224BB/BEBS SATA Black Internal 24x Speed Plus DVD±RW Drive
10/100 PCI network card
CoolerMaster RC430 Black Edition 500WPSU
Razer Lycosa Backlit Keyboard Mirror Ed
That GPU isn't the best, so if you are planning on doing gaming I would recommend the Radeon HD 6850. Also, if you aren't planning on overclocking, just use the cooler that comes with the CPU.
7750 is better than a 6850....
