Custom Cables For NZXT HALE82 700w
A crazy pc dude
74
Ive been looking around but i cant find any cables for the nzxt hale 82 700w. My system looks a bit boring. As well as the 24 pin is a bit to short for routing it behind the motherboard tray. I have the Phanteks Enthoo Pro.
You would be served well by going with a sleeved extension kit instead of a full custom length kit since the latter would be expensive and the wiring diagram to it would be near impossible to find.
Is it the V2 version or the first revision? Have you tried contacting Ensourced and asking them if they can make a custom length kit for you? I would like to ask one other thing though, why are you spending on a unit that is somewhat cheap and not good when compared to the competition? It only adds more negative return on investments.
I ended up getting it dirt cheap on new egg one time and i was really looking into a rm650i but it was way out of my budget. I just want to get the most out of my system and its a better upgrade from what i had originally. Yes its the V2
