Custom PC front panel
joseph9012
Commendable
Apr 14, 2016
301
Does anyone know where you can get a custom front PC panel with audio ports, USB ports and a power button. It is for a custom PC desk case and preferably not ridiculously expensive.
I am looking for something like this
https://imgur.com/a/Bir86ET
Or something like this but with audio ports,
https://www.overclockers.co.uk/lian-li-bz-u08b-5.25-usb-3.0-power-and-reset-button-panel-black-ca-611-ll.html?gclid=CjwKCAjwt5DXBRAtEiwAa3vyEtT8dHdGHhvlPCzwdWzyfYuCh_tvKWF5Xyk87sFxFA78IaXo4E7n5RoC464QAvD_BwE
You either diy it or get the one you linked. You can also get some cheap ones from ebay or from a broken case. What the budget?
Preferably around £30, the first link was a case and the second link didn't have any audio ports.
Another option would be to look for one with just USB 3 and Audio ports, then buy a separate power switch that can be installed through a hole in the case, such as these, for example...
https://www.overclockers.co.uk/search/index/sSearch/power+button
