[SOLVED] Custom PC help, urgent assitance required pleaaaaaase :(
Aug 20, 2021
Hi,
So i have build a custom PC and have re-used a SSD from a previous PC. I can boot into Windows fine but when attempting to access the BIOS the 'Boot' light (red) turns on and it seems to crash on the boot screen. If i allow it to boot as normal without attempting to get into the bios it loads windows fine.
I've tried to unplug everything one a time and restart the PC with no luck. I've attemped to reset CMOS and change the battery just in case.
Gigabyte B450 Aorus Elite
Ryzen 5 3600
16GB Corsair Vengence pro 3600 Mhz (Currently only running at 2x1064 mhz) need to access BIOS to fix this
EVGA RTX 2060 KO
Hi,
Ryzen 5 3600
EVGA RTX 2060 KO
What happens if the "used" disk is not connected?
Using a previous Windows install is not reliable with a motherboard swap. For best reliability, you need to do a clean install.
Reactions: kurdtnz
