[SOLVED] Custom PC Help
You don't need the thermal paste. The CPU comes with a heatsink with a quality thermal compound pre-applied to it.
Otherwise, that is a decent "budget" build overall (not a huge fan of the PSU, but it is adequate).
What about Windows? Also, I assume you have all the other typical peripherals.
Yeah just need the system.
The m.2 is alright for your operating system, but I would buy a new drive or just upgrade to over 500gb before installing anything. Even a cheap 1TB hard drive will suffice.
