[SOLVED] Custom pc not starting up
Dec 19, 2018
Hi, i recently built my custom pc but it wont start up. I followed a video and it said eliminate each part 1 by 1 to figure out the problem.
I found when i unplugged the 8 pin cpu cable everything else would start up fine. So the problem is obviously something with power to cpu.
What should i do to correct this? Do i need another cpu? or have i done something wrong that i can correct it?
thanks
colin
