Custom PSU Cables for Seasonic X-850 (KM3)
dalinkwent
19
So I've been looking for custom cables for an upcoming build and I finally found what I thought was the right set. I recently looked into it further and found out that these cables were for the Seasonic X-1000, 1050 and 1250.
My question is do you guys think that they'll work? The reason I ask is because I can't find anywhere in the US that does custom sleeving for this PSU and will let me choose the colors of the cables. My theme is black/purple/teal, so it's not something that is easily found (at least not for me).
If anyone knows a place that sells fully sleeved cables (not extensions) for this PSU could you drop a link?
I'm also looking for black sleeved single SATA power connectors, I've been able to find cables with multiple SATA power connectors but none with just a single SATA. I have the Define R5 and would like to mount an SSD to the back and an HDD in the cage without having to deal with 3 extra SATA power connectors.
Link to PSU - http://bit.ly/1P4YJxl
Link to Custom Cables - http://bit.ly/24W2PU9
Extension would work in similar manner. I would recommend getting cables from primo chill. They have been making custom cables for a long time.
Thanks, that makes me feel a lot better.
Another question: I found a section on PrimoChill's website that allows you to create your own custom cables, but when you look at the description of the cable they keep calling them "extensions". My question is could I use these cables for the Seasonic X-850 as well, as long as I get a long enough cable? I ask because I need 2 separate 8-pin PCI-E cables for my GPU, and the set they offer for that PSU only comes with dual 6+2 connectors.
Link to cables in question - www.primochill.com/product/kobra-maxcord-8-pin-pci-e-cable-designer/
Thanks again for your help, I appreciate it.
