[SOLVED] CyberPower CP1300EPFCLCD Replacement Battery?
parisisal
5
Hi,
I know that CyberPower CP1300EPFCLCD uses RBP0124 Replacement Battery?
The RBP0124 is composed by two HR1227W F2 Battery 12v 27w. This kind of batteries are not so common, it's hard to find this model in a reseller.
I noticed that CP1500EPFCLCD has the same dimension of CP1300 and uses inside the RBP0016 (standard 12V 7Ah batteries).
Question, Could I use for the CP1300EPFCLCD the RBP0016 ?
Any experience ?
Thank you,
Salvo
sure u can use it, but it has different dimension, so it may not fit in enclosure
RBP0124 180 x 70 x 102 mm (WxHxD)
RBP0016 201.5 x 65 x 151 mm (WxHxD)
its two 12v batteries connected in serial (for 24volts)
