Cyberpower vs. Ibuypower *Help
m3k
Thinking about picking one of these systems up. Need some of your help in pulling the trigger. Check out these 2 builds and let me know what you think. Primary goal is gaming with min to no lag, MMO's and shooters, i.e. Aion, MW3. Here we go.
1st system specs (ibuypower):
1 x Case ( NZXT Source 210 Gaming Case - White )
1 x Processor ( Intel® Core™ i5-2500K Processor (4x 3.30GHz/6MB L3 Cache) )
1 x iBUYPOWER PowerDrive ( PowerDrive Level 1 - Up to 10% Overclocking )
1 x Processor Cooling ( Liquid CPU Cooling System [SOCKET-1155] - [Free Upgrade] Standard 120mm Fan )
1 x 8GB (4GBx2) DDR3-1600 ** Corsair or Major Brand )
1 x Video Card ( NVIDIA GeForce GTX 560 Ti - 1GB - EVGA Superclocked - Core: 900MHz - Single Card )
1 x Motherboard ( [SLI] Gigabyte GA-Z68A-D3H-B3 -- 3x PCI-E 2.0 x16, Lucid Virtu Technology )
1 x Motherboard USB / SATA Interface ( Motherboard default USB / SATA Interface )
1 x Power Supply ( 700 Watt -- Standard )
1 x Primary Hard Drive ( 500 GB HARD DRIVE -- 16M Cache, 7200 RPM, 6.0Gb/s - Single Drive )
1 x Optical Drive ( 24X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive - Black )
1 x Sound Card ( 3D Premium Surround Sound Onboard )
1 x Network Card ( Onboard LAN Network (Gb or 10/100) )
1 x Operating System ( Microsoft Windows 7 Home Premium + Office Starter 2010 (Includes basic versions of Word and Excel) - 64-Bit )
1 x Warranty ( 3 Year Standard Warranty Service )
Price on system above is $1132 total includes tax and shipping.
system #2 below (cyberpower):
CAS: CoolerMaster Elite 430 Mid-Tower Gaming Case with Side Panel Window
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
COOLANT: Standard Coolant
CPU: Intel® Core™ i5-2500K 3.30 GHz 6M Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FAN: Default case fans
FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
HDD: 500GB SATA-III 6.0Gb/s 16MB Cache 7200RPM HDD [+8] (Single Drive)
IUSB: Built-in USB 2.0 Ports
MEMORY: 8GB (2GBx4) DDR3/1600MHz Dual Channel Memory (Corsair XMS Gaming Memory with Heat Spreader)
MOTHERBOARD: [CrossFireX] GigaByte Z68AP-D3 Intel Z68 Chipset DDR3 ATX Mainboard w/ Intel Smart Response Tech. & 7.1 Dolby Home Theater Audio, GbLAN, USB3.0, 2x SATA-III RAID, mSATA Connector onboard, 2 Gen2 PCIe, 3 PCIe X1 & 2 PCI (All
MOUSE: XtremeGear Optical USB 3 Buttons Gaming Mouse
NETWORK: Intel Pro Gigabite 10/100/1000 Network Card [+34]
OS: Microsoft® Windows 7 Home Premium [+104] (64-bit Edition)
OVERCLOCK: Pro OC (Performance Overclock 10% or more) [+19]
POWERSUPPLY: 700 Watts - XtremeGear SLI/CrossFireX Ready Power Supply [+10]
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: NVIDIA GeForce GTX 560 Ti 1GB 16X PCIe Video Card [+128] (Major Brand Powered by NVIDIA)
Total price on this system is $1209, includes tax and shipping.
Was curious what you guys/girls thought about these 2 rigs and what you would choose given prices and goals, system #1 or system #2. Please feel free to post up, value all your opinions. Another option of course is something different then above that will perform the same and cost less. I priced these out to build it myself and it came to $1012 before tax, figured the extra $100 was worth the support and me not having to build it. Let me know what you think. Curious about the 2 company's also, not familiar with either but both "appear" to build excellent systems.
Thanks again.
Actually, they are both pretty similar component-wise. The first choice has an OC'd graphics card. But more importantly, if you ever plan on doing 2 cards, the first choice has better PCIex16 slot configuration. You can run 2 cards at x16, x8. Whereas the 2nd choice limits you to x16, x4 when running two cards. Trust me, you don't want to do x4 with a 2nd 560ti. So my choice would obviously be the one with the Gigabyte GA-Z68A-D3H-B3 motherboard.
I bought a system from cyberpower once with the same logic, I found I prefer making my own computers...no issues from cyberpower, prompt delivery, got exactly what I asked for.
