[SOLVED] Cynosa V2 f keys problem
Jan 5, 2021
4
Just bought a new keyboard razer cynosa V2 and some how when i was doing the config the f keys stopped working
Pls help
See if pressing Fn+F9 changes your experience. That is, I'm assuming you're in Macro record mode, there should be an LED indicating what mode you're in. Also, did you install Razer's Synapse app?
Yes i installed it they worked for a while fn f9 i tested does nothing the led icon dont even light light up im starting thinking they are faulty but its 12 keys faulty seems a little bit hard.
Im thinking its the gaming mod but will try that when a get home
