This device can fit into your pocket.
D-Link Ships World's First Portable Wireless AC Router : Read more
well lets face it there are not many places in the world that have greater that 100Mb internet access which is what that port is for. You might as well say that every AC router is useless if you dont have more than 300Mb internet. You use that speed to transfer files/stream over the network not for the internet.I quite like the device, would defiantly come in handy for meWhy is a AC Router only equipped with 10/100 Ethernet port?This doesn't make any sense...
You have got the wrong idea. That 300mbps wireless is useless as it'll be bottlenecked to 100mbps if you're transferring files/stream over the network which is connected by the ethernet socket.You might as well say that every AC router is useless if you dont have more than 300Mb internet. You use that speed to transfer files/stream over the network not for the internet.
Because it's D-Link. Their products are garbage. Buy TP-LINK and Asus instead if you're in the consumer sector. Alternatively, they (D-Link, not Tom's, 10/100 is also quoted on the D-Link product page) copy-pasted specs from somewhere and didn't bother to verify. But I'm leaning towards the former reason.Why is a AC Router only equipped with 10/100 Ethernet port?This doesn't make any sense...
