[SOLVED] d-sub and vga
Brendon_Austin
17
I am getting a new motherboard and im using an igpu cpu.
I have D-sub and dvi-D on my new motherboard and on my monitor i have VGA, DP and HDMI on my monitor and i was kinda sure but unsure that i could conect a D-sub with VGA nad was wondering if i needed an adapter or not.
Thank You!
Thank You!
The 'D-Sub' connector is just the technical name used for a standard VGA port, so no adapter required.
Thank You!
Reactions: Brendon_Austin
Merged threads due to being the same topic.
You could also look towards buying a motherboard that conforms to your display input needs on the monitor, as opposed to buying adapters but that will prevent you from migrating onto a latter standard of display connectivity.
