D5 pump control
slyverine
789
Hello there. I have a custom loop water cooled pc, my specs are at my signature. Yesterday, a friend of mine who is building my pc came and we added water cooling to my motherboard and changed my pump to a EK-D5 PWM G2 Motor (12V DC PWM Pump Motor) .
On my RIG i have 4 fans. The fans you need to know more are the 2 fans that cool one double radiator , that they are connected to cpu and cpu opt header(the fans are not PWM). The water pump is connected to the header above , which according to manual is water pump header.
My problem is that i can't control the speed of the pump from AI suites fan expert! I pressed tune, it found the characteristics of fans but when i change water pump speed, it just doesn't change the speed.
What i can try?
1. the headers can control both PWM and non PWM devices. make sure you select PWM mode for the pump.
2. there is no practical difference in cooling with pump speed over 30%. (that's why IMHO D5 Vario is the best, set on 2 and forget)
I just transfered his words 😛 From what i understood he wanted to say that if the motherboard doesn't detect a PWM signal on cpu fan ( a non PWM capable fan is connected atm at cpu fan) , it just thinks there is no PWM signal and thus, i can't control my water pump for that reason.
Guess you are right, but, the way my setup was i couldn't change anything to pump speed it was working on 100%.
I fixed my problem, i plugged my pump to cpu fan header and the 2 radiator fans one to cpu opt and one to where the pump is supposed to go. I can now control my pump speed! Iam working my pump to 60% and it slighty makes a "wave" at the top of the reservoir, i have it half full i want to watch the water.
Iam gonna remove one fan though from cpu opt and connect it to the other header with the other one with a y splitter because the fan is working with the pump speed and i can't control it, and i want to make my pc silent when iam not gaming.
