Here's a quick rundown of what my question relates to:
Purchased Coolermaster's 212 Evo CPU Cooler.
Tried to install it on my Gigabyte Z77-DS3H
During installation, I broke my motherboard's CPU pins. Am now not able to start computer, since during start up, it starts for 1-3 seconds and then shuts down again--yes, EVERY cable that is necessary to be plugged in IS plugged in. My other fans don't turn on after those seconds have passed - nothing turns on after those seconds.
Does damaged motherboard CPU pins cause this or am I looking into another problem?
I am going to re-purchase this motherboard and try again. I want to know whether it's worth going through this hazard to install the 212 Evo CPU Cooler, or whether I'm simply better off using stock cooler (which keeps CPU at 30C during idle).
It is tremendously difficult to install - very difficult to put in words. Even when not applying any major force during installation (though necessary), it still seems to be at the verge of damaging my motherboard's pins, although the 212 Evo IS compatible with my current motherboard!
