[SOLVED] Dark Base 700 - connecting front LEDs
Mar 2, 2020
Im trying to connect the front panel LEDs of my dark base 700 tower to my x570 auros elite wifi mobo.
The case comes with a little panel behind the mobo stand with a series of pins to connect the fans and LEDs.
I see a cable attached to this panel that is supposedly meant to be attached to the mobo in order to turn on the leds, but the booklet for the case doesnt even mention this cable or where it goes. I tried plugging it into each of the LED pins on the mobo, but none of them worked.
Has anyone here used this case before that knows where to connect the front LEDs?
index.php
(C) needs to connect to your motherboard LED port.
to enable motherboard controlled front panel LEDs you have to hold down the color change button for 3sec.
Thanks for the reply. This was how I had set it up the first time. I think that panel might just be faulty, the case fans wouldnt work either until i unplugged the cables from the panel and plugged them directly into the mobo.
