Does anyone know which direction the fans are? I installed it facing the ram modules with the premounted 120mm fan and then i put the 135mm fan in the middle (with the logo facing the same direction). Basically the fans are in line with my rear case fan. Is this correct? Should the middle fan have its logo facing the same way as the front fan?
