I dont see how you can get 90C with wraith prism especially if you have a decent airflow case , probably will just be louder. I personally used the wraith prism cooler with older chips (Ryzen 5 1600 and 1400) and i was able to overclock them at 3.8-3.9Ghz with no thermal problems overall.I really don't want to use the stock cooler. I don't want to see the 3900x going to 90C under load.
The Dark Rock Pro 4 Ram Clearance is ok with the Trident Z Neo RAM.
I just wanted to know if the Dark Rock 4 was a good cooler for the 3900x and If I really needed that beefy dark rock pro 4.
What about the NH-U12S? (CHROMAX of course!) Performs close to the Pro 4 for cheaper.
PCPartPicker Part List
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler ($69.95 @ Amazon)
Total: $69.95
Generated by PCPartPicker 2020-03-05 15:49 EST-0500
Yea, you really can't go wrong with any of them as they will all be quieter and offer better cooling then the stock CPU.Would the Dark Rock 4 be an ok choice too?
For the same price I'd get the Pro even if it ruined the view of 1-2 sticks. You could always put in dummy rgb memory although I don't think they make them for the Neos and may look weird if they're the Corsair ones.
Hi everyone.
Is the Dark Rock 4 enough for a 3900x or should I get a Dark Rock Pro 4?
I won't be overclocking. Just want good temperatures.
maybe is too late maybe not but i have ryzen 9 3900x and dark rock pro 4...i dont overklock my pc and temp are good i test with CinebenchR20 its around 69 70 max...i have case fractal design mesh c and not add any extra fan yet...that tems are with minimum fan rpm
Hi dimtodim. I built the system like a week later. I have the same temp in Cinebench 20 and it's idling at around 34C. Got a P600S case with 6 fan and yes the temperature is at minimum fan rpm. It's very quiet![]()
did u do some setting in bios about voltage...today my cpu temp underload is around 45c...i dont have air condition in room and its late summer here but not too hot in room...yesterday i make pc build to day is second day using ryzen 9 3900x and dark rock pro 4...only change what i made i close pc case with glass panel...soon as possible i will add extra fan in case. and last question did yout temp jumpin around 10c up and down?
