[SOLVED] Dark rock pro 4
DeanTH23
159
22
4,615
Hi,
I'm interested in purchasing the Be Quiet Dark rock pro 4.
Motherboard and case's compability fine but i currently use a pair for Corsair Vengeance RGB Pro which can be a potential issue.
Specs: ASUS X570 TUF
CoolerMaster MB520 RGB CPU Cooler Max Height 165mm.
Corsair Vengeance RGB Pro Height 51mm
Dark Rock Pro 4 RAM Clearance 40mm Height 162,8mm.
RAM sticks are on A2/B2 configuration.
According to these infos,i can only elevate the outer fan for about 2mm so it's impossible to use this fan or this push/pull configuration with these sticks.
So my questions are:
1) Is it ok to go for a pull/pull setup to eliminate this issue? Case's airflow is good but i don't know if it's enough.
2) Can i buy a smaller fan and go for a triple fan setup,using the available fan mounting metals they're providing us with? Which scenario it's the best?
Thank you.
Just move the front fan behind the 2nd tower - then again, the I/O shield could be too big, so you'd have to take the measurements yourself.
