I am desperately trying to recover files and photos from my external hard drive. I have a Seagate FreeAgent Go 500GB. It still runs and lights up, but when I plug it into my latop, it wasn't recognized by the laptop. After much searching online, I finally just sent an email to the Seagate people asking for help. They said due to the age on the drive, it's no longer under warranty, but felt that the data was still able to be recovered. Per their recommendation, I got a USB to SATA cable.
So I got the cable, took the hard drive out of the casing, but when I hook up everything to the laptop, it still doesn't work. The drive does not show under My Computer. It does show in Printers and Devices as "ASMT 1051," but I can't get it to do anything other than open its Properties.
In Computer Management, I can see the hard drive listed in a couple places...under IDE ATA/ATAPI controllers as AMD SATA Controller. And under Storage Controllers as USB Attached SCSI (UAS) Mass Storage Device.
In Disk Management, the hard drive is listed as Disk 1, but I get a pop up that says "You must initialize before Logical Disk Manager can access it." with the option of Master Boot Record and GUID Partition Table. In my search for solving this data recovery issue, everything I've read says that if you click to initialize the disk, it will erase all of the data on the hard drive, so I'm not really sure I want to do this...
I downloaded and tried Partition Find and Mount, which told me that there are no visible partitions, and I also downloaded Recuva, which I don't know how to get it to do it's data recovery thing because there's not a letter assigned to the hard drive or something, but that's probably operator error.
I'm totally at a loss of what to do with it now. Hoping somebody might be able to offer some help...
Almost forgot, I have Windows 10 on my laptop.
