I plan to buy 8 GB memory.
Is there significant difference between memory timings 4-4-4-12, 5-5-5-12, and 5-5-5-18?
The price for CAS4 is expensive, about $120 or so.
5-5-5-12 is $30 cheaper, and 5-5-5-18 is about the same as 5-5-5-12.
Now I have 2 GB of that 5-5-5-18 one.
If the difference between 4-4-4-12 vs. 5-5-5-18 is noticeable, I might buy the CAS4, considering this is the last upgrade so I wish to expect an optimized buy and performance.
On the other hand, my mobo supports 1066 OC, so should I buy DDR2-1066 instead? But the price is about the same as 800 4-4-4-12.
