Question DDR4 2400MHZ(stock) oc to 3200MHZ succesful but need help.
eliendrel
33
Hello I oc my hyper x fury 2x4 gb ram 2400(stock speed) to 2933 with the same timing (15-15-15-34) and same voltage 1.2 i tested it with memtest86 and there were no errors but i would like to know if that's normal that on cpu-z next to DC mode it is blank is the dual channel mode working fine?
Could you let me know if something is wrong please?
Here is my computer's spec:
cpu : ryzen 5 1600 3600MHz @1.13v
cpu cooling: stock
gpu: GTX 1080 stock
ram: hyperx Fury 2x4gb ram DDR4 2400MHz 15-15-15-34 1.2v
Motherboard : Prime B350M-A
The blank entry is normal and nothing to be concerned about. If the system is stable at these OC speeds, then game on. Have you benchmarked the system to put under a full load yet?
Not yet i'm using the cpu at this clock for several months now it's stable but about the ram I don't know i just tested it with memtest86 for 1 hour and half it was fine i'll soon try to oc it to 3200MHZ and then i'll start benchmarking the whole system. I already benchmarked the whole sytem but with 2400mhz
