[SOLVED] DDR5 DRAM Frequency stuck at 2400 Mhz
Mar 20, 2022
For some reason, my DRAM frequency is working at 2400mhz instead of 4800. I have a GIGABYTE Z690 UD AX, and I was told to update the bios, and I did, but that did not solve the issue. What should I do? (Both rams are placed correctly)
CPU: intel i5 12600 kf
RAM: kingston 166x2 ddr5
Where exactly does it show your speed? If it's in the BIOS, try figuring out if XMP is enabled and turning it on if it isn't. If it's in CPU-Z, then what you're seeing is correct. It's showing the rate that is doubled, since it's DDR, or Double Data Rate.
I use CPU-Z and it says the DRAM Frequency is 2400, yet the BIOS is saying 4800, who should I trust now?
