MSI shares its thoughts on the initial pricing for DDR5 memory kits.
DDR5 Will Probably Cost 50% to 60% More Than DDR4 : Read more
Writer's gotta eat.Is this really news? New RAM tech is always more expensive than older tech. That's how it works.
DDR was more expensive than DRAM when it first arrived
DDR2 was more expensive than DDR when it first hit the scene.
Same with DDR3. And DDR4. And now DDR5.
It definitely new when its reported to be this much more while also being much slower.Is this really news? New RAM tech is always more expensive than older tech. That's how it works.
Except this time around, you have the on-DIMM VRM, data and control buffer chips adding a significant chunk of cost that didn't exist on previous mainstream memory tech, which are going to greatly increase the baseline costs that cannot be optimized out of the design and mean DDR5 will remain at a relative premium until DDR4 prices rise from getting phased out of production.Is this really news? New RAM tech is always more expensive than older tech. That's how it works.
What do you mean by it slowly killing the motherboard? Was is significantly overvolted to get to 1600? I remember in my 3570k build DDR3 was natively 1333 or 1600 cl9I recall dropping $300 on DDR3 1600 3x4GB kit. Not doing that again, especially to only have it slowly kill the motherboard.
1.65 volts even for ddr3 is comical.X58 and 1st gen i7-950. 1066 was the launch speed, 1333 mid range and 1600 full blast at 1.65 volts, and it needed it to work.
Between motherboards requiring more layers to maintain signal integrity at ludicrously high DDR5 and PCIe5 bus speeds, along with the rising costs of raw materials, their processing and shipping, unfortunately no.So motherboard's be cheaper relocating these components ?
