Decent Video Card for a 350w Power Supply
xalb12
Hi all,
I just got a refurbished dell Vostro 470 MiniTower with the following specs :
Processor: Intel Core 3rd Gen i5-3450 Processor (3.10 GHz with Turbo Boost 2.0 up to 3.50 GHz)
HD : 500GB - 7200RPM, SATA 3.0Gb/s, 16MB Cache
Power Supply : 350W Power Supply
RAM : 4 GB Dual Channel DDR3 (1600MHz)
OS : Windows 7 Home Premium
Dell Wireless 1703 802.11a/b/g/n, Bluetooth v4.0
I am installing a Samsung 830 128GB SSD as a primary drive and I was thinking of installing a decent video something my power supply can support. Here is a link of the power supply specs. http://imageshack.us/photo/my-images/521/photo1dn.jpg/
any input will be greatly appreciated.
miwyi
11
Can you assure me a 7770 would work on 350watt psu ? like more than certain, cause i would buy one now.
aqualipt
1,150
Yes, it will definitely work but i check if your PSU has a PCI-e power connector.
Well its a Dell, so the power supply is actually viable in terms of actually being good. I would recommend the 7750 still. It would have much headroom to run. That would be my recommendation.
miwyi
11
Considering this i need 388w for the 7770 and 356w for the 7750,
Test with current vga is 349watt , Seems fair enough ... So yeah i think ill be upgrading the PSU aswell .
Would this Work ?
http://www.amazon.com/Cooler-Master-eXtreme-Supply-RS500-PCARD3-US/dp/B001G0WPLK/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=2H363AXGW4SX2&coliid=IXXX54UVMOJ5A
DavidY
276
Not a good power supply.
Your minitower is the limiting factor for your power supply....these are pricey in the higher watt segment.
Stick with the HD 7750. These have been put into 250-300 watt power supply systems.
Dave
miwyi
11
Thanks for link Everybody Really useful, I'll stick with cheaper one, i didnt wanted to spend alot at first.
And basically with a Decent PSU the 7750 is still better ? or i shall stick to the 7770 :D
regina_49
437
either will work you decide 7770 is better than 7750 ;)
DavidY
276
Mine was DOA. Had to pay $17.xx to ship it back to Newegg.ca too. :(
Dave
DavidY
276
Corsair Builder Series are not my favorite power supply....only would buy it if the selection or budget was extremely limited. Too many reports of whining noise.
Dave
