Is there any way to find out if a motherboard is sending flase readings to hwmonitor, speccy, cpuid, and etc
For a while now I've been noticing a odd issue mainly between two programs on older systems..... Not old old but it's an older system I am facing the issue with now. However this system might not be giving false readings I can't be sure on this though because like I said I have had issues where the system just isn't providing proper readings and other times where everything is fine....
Is there any way to figure out if temp readings are right or if the sensor is shot/not reading right one. Or is it basically ride or die and just risk the temps being false...
The main reason I'm thinking their false temp readings is, the moment the PC fully boots I open 2 apps the monitor the temps hwmonitor and speccy, they both right off the bat say 115c for the mainboard temp and the other one will say 112c mainboard temp.... But neither ever agree on the temp the mobo is they just right away say ove 100c
